Results 1 to 5 of 5
Thread: Everlast Argon regulator upgrade
    Default Everlast Argon regulator mod
    Hi all. Not sure if this belongs is this forum or not, but I will start here. I bought a 250EX at the end of last year, what a great machine. So much better than my old 225LX.
    Anyway, one thing that I have never liked was the water hose that comes with the welders for gas line. Using a standard hose is not really possible with the regulators that come with these machines. After looking for an adapter and not finding one, I made an adapter.
    Here is what I did:
    I started by removing the soft Everlast hose off the regulator fitting.
    The second needed part is a standard CGA fitting, I forget what is was called but it is the standard gas hose to 1/4" pipe.
    I started by removing the pipe thread off the CGA fitting. Then I just enlarged the hole with a drill bit, I can't remember what size, but I opened it by about 0.04". It is important to leave as much wall thickness as possible on both the barb (see below) and the CGA fitting. I drilled the hole about 1/2" deep. If you drill the hole all the way through you will mess up the CGA sealing surface.
    This next shot should be of turning the barb down so it is nice and smooth, but I forgot to take a pic of that step. I turned it down to about .003" smaller than the bore in the CGA fitting so it was a nice slip fit. This left about 1/16" wall IIRC.
    The shot below is after machining both parts.
    This shot is after cutting the barb side down to about 5/8" to insert into the 1/2" deep hole.
    Here it is all soldered up.
    And the money shot, an adapter from the metric regulator to CGA!
    I love the mod. What I probably love the most is that the huge gush of shielding gas when you first step on the pedal is almost gone. I am using a really nice Radnor hose now (Goodyear).
    Nice job on the fitting, and welcome to the forum.
    Lincoln A/C 225
    Everlast P/A 200
    My new reg. from buying my MTS250S is sitting in a box on a shelf for this very reason. I have no clue why the industry standard fitting is not used but it is not worth my time to mess with it. So on the shelf it will stay. Fotunatly I had several extra regulators, most of which are 30 years old and still working perfectly. I am glad you were able to fix it up to be usable. Nice job.
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
    Thanks guys!
    Jun 2014
    Ontario, Canada
    The regulator fitting is most likely an oxygen B Size fitting, at least my Chinese princess auto one is, It took me for ever to figure out what it was.
  1. Name that argon fitting! Or, where do I buy the QDs Everlast uses?
    By RichardH in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 06-07-2014, 07:31 PM
  2. Hose Upgrade on Supercut 50P Regulator
    By cbmkr in forum Technical Bulletins and Tips
    Last Post: 07-12-2012, 09:35 PM
  3. Replies: 7
    Last Post: 03-22-2012, 04:46 AM
  4. argon regulator
    By Max Power in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 11-19-2011, 08:39 PM
  5. Argon regulator leak
    By robsthomson in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-15-2011, 06:21 PM
