Results 1 to 19 of 19
Thread: VFD (variable frequency drive) for drill press.
    Aug 2014
    Westerville, Ohio
    Default VFD (variable frequency drive) for drill press.
    Picked up this 3 phase 220 volt 1.5 HP electric motor off Craigslist for $25.00. The seller had no way to demonstrate functionality so that's all I was willing to pay given the risk it was junk.
    I ordered the VFD drive with plans to install the setup on drill press *if* the motor functioned okay.
    The gamble paid off. This is one neat upgrade!
    Here's a photo of the unit set up as a garage floor bench test.
    Quote Originally Posted by fyidiy View Post
    What is the model and rating of the VFD?
    Does the motor to develop sufficient torque at low RPM's?
    Thanks,
    rivets
    Aug 2014
    Westerville, Ohio
    Here's all the motor's information.
    Sufficient torque? Considering this isn't going to be a 1:1 drive ratio it should have enough speed to generate more torque than the belt system is capable of transmitting.
    A basic VFD will not have a lot of torque at slow speeds. To overcome that many VFDs have a tach input so the drive can boost the motor when it is stalling. There are also issues with proper cooling at low speeds. The best thing is to setup the belt system so the motor runs at nameplate speed or above for most operations. Inverter duty motors can be overdriven way over speed. Standard motors can still go a lot, but the insulation might have issues with very high frequencies. It's always better to run the motor over speed than under. Many VFDs can go as high as 400Hz so the motor will run 6.6 times the nameplate speed. While that motor probably can't handle that, it can at least do double or triple speed. Then setup your belts to get the max spindle speed you want and use the VFD to go down from there. If you plan on tapping or drilling super large holes in hard materials, you still may need to swap a belt from time to time.
    Aug 2014
    Westerville, Ohio
    The motor with the old bearings made rattled and vibrated. Apparently, the previous owner of the motor thought it did too. The interior was stuffed with too much grease.
    I cleaned up the mess, pulled the old bearings, and replaced with new. If you need bearings try CBR Bearings. I've been dealing with them for years for wheel bearings on dirt bikes and street bikes -- small company with big individualized service. I have no interest in them other than as a satisfied customer.
    With the old bearings I set the max hertz to 150. With the new bearings it's silky smooth all the way to the VFD's max hertz drive of 240.
    #1 Armature and old bearings removed. New bearings in boxes on right.
    #2 Old bearings above and new bearings below. Steel tube to be used for pressing on the larger bearing.
    #3 Large bearing being seated in the hydraulic press.
    #4 More detail of the armature. The black socket in the lower left was used to seat the smaller bearing.
    #5 Armature with new bearings installed waiting for motor reassembly.
ID:	12786Click image for larger version.
ID:	12782Click image for larger version.
ID:	12783Click image for larger version.
ID:	12784Click image for larger version.
    Aug 2014
    Westerville, Ohio
    Scrap yard sourced 5"x5" tube of 10 gauge used to create a new larger mounting bracket for the 3 phase motor. It's on my list to acquire but have yet to add one of Swag Off-Road's DIY bending break kits for the 20 ton HF press. So, to create the necessary shape of this bracket I just used the tube's corner stock.
    The nice thing about operating the plasma cutter in the winter... No moisture problems with the compressed air.
    In addition to the seam welds there are three plug welds on each side to keep it all together.
    Once the final holes are drilled the bracket will receive a cleaning and painting.
ID:	12797Click image for larger version.
ID:	12794Click image for larger version.
ID:	12795Click image for larger version.
    Aug 2014
    Westerville, Ohio
    Today the box for the VFD was fabricated.
    Photo #1. Nice clean edges of the 5"x5" 10 gauge tube after cutting.
    Photo #2. Assembled box, top, and mounting flange all welded together.
    Photo #3. Right side of the box so more of the mounting tang is visible. Three plug welds as well as a couple of lap joint bonds.
    Photo #4. Box mounted to drill press. The black motor mount was fabricated earlier in this thread.
    Photo #5. Test fit of VFD electronics. Mounting holes for the VFD as well as power cabling holes still need to be drilled.
ID:	12831Click image for larger version.
ID:	12832Click image for larger version.
ID:	12833Click image for larger version.
ID:	12834Click image for larger version.
    Quite a sturdy box. Be sure you meet the ventilation requirements of your VFD. They often specify to be mounted a minimum distance from vent obstructions. Is it passive or fan cooled?
    Aug 2014
    Westerville, Ohio
    Cooling should be okay; the heat sink on this unit is *huge*.
    FYI, when researching VFD and other drill press modifications I found these guys:
    https://www.roguefab.com/category.php?category=DPRKS
    Aug 2014
    Westerville, Ohio
    The VFD is capable of accepting 110 or 220 volts single phase to create the 220 volt 3 phase output. Currently there's no 220 permanent service in the garage. For various welding projects I just run a temporary extension cord from the electric oven circuit.
    So, the wiring for the drill press needs to be beefy enough to deliver the necessary amps.
    A photo of the wiring work-in-progress.
    Nova Scotia, Canada
    Careful running that motor that fast. It won't like it for long.
    240Hz = 7200 RPM.
    240Hz = 7200 RPM.
    With the right bearings it should be no problem to run at that speed. BTW your math is a bit off as 240Hz on this motor will be 6960 rpm.
    Aug 2014
    Westerville, Ohio
    There's no need to run it that fast for anything other than a no-load demonstration.
    The protective box/hood paint job finally dried and I managed to get it all mounted up and wired into the drill press.
    Turning it down to 10Hz in order to test cut a 1.5" hole saw hole in 1/4" plate steel worked perfectly. Being a 1.5HP motor there's no stalling it at such a slow setting. However, the belt system can be made to slip with enough downward force on the quill.
    All in all, I'm happy with the resulting functionality of the project.
ID:	12905Click image for larger version.
ID:	12906Click image for larger version.
    Aug 2017
    Clifton, Texas
    Not worried about the bearings - - is the rotor balanced to handle those speeds?
    Will centrifugal force cause anything to become dislodged, warped, or fly off?
    Quote Originally Posted by LincTex View Post
    The post you're responding to is over 2 1/2 years old. It's no problem but it's good to check the dates before replying. I'm sure the man has no use for the higher speeds. The purpose would be to adjust speed for different size drill bits without having to move the belt between different size pulleys. 50-3000rpm would be plenty of range.
    Aug 2017
    Clifton, Texas
    Yes, but I come back to old posts after several years all the time on other forums, as long as it is still relevant information, or updates are needed. If there is a concern, it would be nice it it were addressed. Like "how does a cheap fractional horsepower belt handle those speeds"? I think that is relevant.
    I may actually try to duplicate this setup.
    I like the concept, and the possibilities.
    Aug 2014
    Westerville, Ohio
    I think this statement earlier in the thread answers the question:
    "There's no need to run it that fast for anything other than a no-load demonstration."
    I have *yet* to need anything faster than 60 Hz. with the VFD-configured drill press. I do, however, utilize reduced speeds all the time since the majority of my press tasks are in metal.
    Aug 2017
    Clifton, Texas
    How much was your VFD?
    I did a quick google search for "single phase VFD drive" and find a lot of attractive units under $200
    I have a 10 HP Baldor 3 phase I can use for no-load testing, but there are literally a TON of cheap 3-phase motors out there to be had in the 1hp & under range.
    Aug 2014
    Westerville, Ohio
    The VFD in this project was just south of $300. I'm sure the prices have dropped since. These things should be around $100 or less in a few years.
  1. Variable shade auto hoods
    By Rambozo in forum General Welding Questions
    Last Post: 06-03-2017, 03:20 PM
  2. drive rolls
    By bandh in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 05-02-2014, 12:24 AM
  3. Deep-well wing nut for drill press locking clamp
    Last Post: 03-03-2012, 07:55 PM
  4. Press brake for modified HF shop press
    Last Post: 06-06-2011, 07:29 AM
  5. 250EX Foot control, variable?
    By RubiconJoe in forum Customer Testimonials
    Last Post: 01-12-2010, 02:19 AM
