Yes you can buy a miller 10 pin femal plug then buy a 7pin plug from everlast to fit your 251. Follow the wire schematics for miller and the mts251 and make a short adapter. I have an mts 250 so I can not tell you for sure that the synergic function and pulse will work but from what I see in the 251 manual I believe it would. Personally I do not see the need for the synergic function for anything. You will need a euro adapter to hook up the 30A to the mig port .
Miller 302 gas drive
millermatic 200 mig
2014 Everlast PP60S plasma
thermal arc 250 GTS inverter
2016 Everlast 250EX
miller tig cooler
2015 Everlast MTS250S
Miller 30A spool Gun
Linde CM 85 shape cutter
