PowerTig 210EXT
Problem :
Upon arrival machine was setup to test workability everything
looked good no visible damage. Then once I ran my first test I noticed the
machine was not putting out enough amprage to create a weld puddle so I
decided to switch out my tungsten rod while doing so, I noticed that the
digital display was no longer working nor any of the other controls (foot
pedal, finger switch, ect.) so I read the manual and did what was advised.
I checked the connections, I plugged the welding machine to an independent
plug when I turned the machine on it sounds as if the machine is running
the fans are running at full blast I've also noticed that if the torch
makes contact with the ground clamp or contact with anything grounded to
the clamp it will produce a small spark as if there is a short circuit I
cannot tell though I've looked in the forms to see if this is a problem
that anyone else has experienced ,but couldn't find any type of
information on this kind of issue so please if could help me resolve this
problem I would greatly appreciate it I will be forthcoming that this
welding machine will not fall under warranty ( I bought as is). I am more
than capable of doing the technical work myself I just need a little
guidance. I was told that maybe the main control board can be reprogrammed
if that is the issue. {If that is the issue what type of connections would
I need? And what software I would need to flash the ROM }
