Results 1 to 3 of 3
Thread: AC Power Requirements - 255EXT plus W300 water cooler
  1. Default AC Power Requirements - 255EXT plus W300 water cooler
    I do not see mention of the AC circuit capacity required for the 255EXT or the W300 water cooler in the manuals. Can someone here give me a circuit size (Amps) to run this rig full-out? Are we talking 40 Amp with #8 wire (30 feet from panel), or will I need 50 Amp with #6 wire or larger? Thanks.
    David
    Mine says 34amp, so 40 is fine, but I would go 50 amps in case you want to get a plasma later and you are golden.
    It's in the manual, page 10. Water cooler manual info is on page 9.
  1. 250 EX water cooler power output.
    By AWDnot2 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-28-2013, 06:56 PM
  2. W300 water cooler
    Last Post: 12-05-2012, 01:53 AM
  3. Water cooler requirements
    By dynasim in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 05-21-2012, 04:46 PM
  4. Added a W300 Cooler
    By Gary in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 08-23-2010, 12:03 AM
  5. Question about W300 water cooler???
    By DisWeld in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-03-2010, 11:28 PM
