Results 1 to 7 of 7
Thread: Rear panel mounted 110 Volt outlet
    Default Rear panel mounted 110 Volt outlet
    Just received my new Powerpro 164 and noticed that it has a rear mounted female 110Volt outlet. My first thought is this is designed to bypass the need for the 220V to 110 Volt conversion plus supplied with the unit; however, it also looks as if the plug needs a very specific cable to fit it.
    Can anyone tell me what this plug is for. It's not shown anywhere on any of the instructions that either come with it or up on the Everlast website ?
    Many thanks for any responses
    Bob Campbell
    Nah,
    I believe that's a direct plug-in for a TIG torch water cooler, which would start up with the welder. It may be a new feature on that model, otherwise it's found on many Everlast units, I believe.
    Thank you for your helpful response. That makes perfect sense. Strange how it's not in the Powerpro 164 manual; must be in the manual for the watercooler
    Quote Originally Posted by rh.campbell View Post
    Bob Campbell
    I believe that plug is 220v but they might have changed the new ones to 110v. I would use a voltage test on it before plugging any thing in to it.
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
    If your unit has a plug it should say 110/220. It is designed ONLY for the water cooler. Do not use it for anything else.
    Yes, it's quite clearly marked on the case as 110 Volts. I guess it must be used for connection of some sort of a water cooler as someone else has suggested
    Yes the IEC connector is for the cooler, but since you have a dual voltage welder, I would measure it running on 120V as well as 240V as it may just pass along whatever line voltage you are running at. Everlast makes a dual voltage cooler that can deal with that, too.
  1. Switch mounted on torch
    By willida in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 05-17-2013, 12:59 AM
  2. 2013 200DX 240 Volt Version First Impressions
    Last Post: 12-06-2012, 09:45 PM
  3. Wall Mounted Coat Rack
    By reesee in forum Metal Art
    Last Post: 10-29-2011, 11:37 PM
  4. Aluminum sheetmetal shroud for under-mounted Horizontal Bandsaw motor
    Last Post: 05-08-2011, 05:07 PM
  5. high duty cycle 120 volt MIG?
    By welderdude in forum General Welder Questions
    Last Post: 04-27-2011, 12:51 PM
