Results 1 to 2 of 2
Thread: How to adjust tension roller
    Mar 2016
    Okinawa, Japan
    Default How to adjust tension roller
    Ok the manual says snug up the tension roller knurl knob but they have numbers on it. So how exactly to you adjust it? I-Mig 140E
    Quote Originally Posted by pavetim View Post
    Tight enough that the wire does't slip while welding. For solid wire MIG you can have it pretty tight with no big problems. With flux core, if it's too tight the wire will get messed up and not feed well. But too much tension is hard on the machine, so you want just enough that it doesn't slip.
    Look on WeldingTIpsAndTricks.com and check out the section on MIG tips. You will learn a lot. Specifically look for the curl test. That will show you how to adjust your tension setting by holding the gun up to a piece of wood and seeing how the wire curls without slipping in the rollers.
  1. Post flow will not stop,and cannot adjust amps just stays on 45
    By Mickhd in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 04-29-2014, 01:14 PM
  2. Powertig 210 ext AC Frequency adjust
    By Lwlandy in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-23-2014, 06:40 PM
  3. Making new band saw tension bars
    By MigPlazArc in forum Other Custom Fabrications
    Last Post: 03-24-2012, 04:07 PM
  4. I-Mig 200 Roller
    By noobie in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 07-21-2011, 07:54 PM
  5. 250 ex hf point adjust
    By kendo in forum Customer Testimonials
    Last Post: 11-14-2010, 10:29 PM
