Originally Posted by
Rambozo
Could be bad gas, but not very likely if the arc is nice and clean over 50 amps. No soot on the welds on thicker plate?
One thing you can do to get you over 50 amps on that material is to move up to a 3/32" tungsten and adjust your AC balance more towards 50%. That will make it so you need more amps to get the same heat in the part. But it's more of a kludge and you shouldn't have to do that. But you can see if things smooth out with the increased amperage. It sounds like something is a little unstable at low amperages. Maybe call tech support and see what they say.
