Results 1 to 2 of 2
Thread: SheetMetal Stick Vs Fluxcore
    Default SheetMetal Stick Vs Fluxcore
    So, I have been welding on some sheet metal lately its all 14ga steel and have been supplied a Lincoln 140hd with .035 Fluxcore wire and its just not an attractive weld at all. It burns through super easy no matter the settings and am considering the use of 1/16" 6013 electrodes instead of wirefeed. It's either that or get a smaller fluxcore wire as its a very windy area. Thoughts? I suppose running the welder off 100ft of 120v extension cord isn't helping any either but no choice for that.
    In the past I did a lot of sheet metal with 6013. I think it works fine, but you might also try 7014. I think you will like the results a lot better than fluxcore, except for the speed.
  1. Power I Mig 200 MIG STICK WELDER , how high should the amp gauge read on stick side
    By Tim L Rogers in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-22-2016, 04:42 AM
  2. 14 gauge sheetmetal tig ballpark ??
    By braveops in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 11-13-2013, 04:36 AM
  3. Brazing/Soldering Galvanized Sheetmetal - techniques?
    By jakeru in forum General Welding Questions
    Last Post: 10-03-2011, 09:02 PM
  4. Project 1 form Revkev6: 1932 ford sheetmetal pinhole repairs
    By revkev6 in forum On Road Fabrication
    Last Post: 08-28-2011, 11:17 PM
  5. Aluminum sheetmetal shroud for under-mounted Horizontal Bandsaw motor
    Last Post: 05-08-2011, 05:07 PM
