Results 1 to 3 of 3
Thread: Power iMIG 275P Wire Feeder Alignment Question
    Jan 2016
    Pismo Beach, California
    Default Power iMIG 275P Wire Feeder Alignment Question
    I have installed .035 flux cored wire on my new i275P unit. I ordered the knurled rollers from Everlast and have just swapped out the rollers, I did one at a time to make sure the fit up/alignment was the same between the new rollers and unit supplied rollers. Now that they are installed and I've run my wire through to the gun tube it appears that the wire isn't directly over the knurled wheel section, it's running what appears down the middle of the grooves on both rollers. First question, is the wire supposed to run on the inside groove like my millers? Second question, is there a way to adjust the alignment of the rollers easily so the wire is over the correct knurled grooves and has anyone run into this issue? Thanks in advance for your help.
    Rj
    Any pics baron....Would be a big help
    Jan 2016
    Sorry everybody, operator error. I didn't actually tighten down the idler roller and verify the wire was laying correctly, with my reading glasses on;-]. Once I did that the wire was in he groves correctly. Thanks Stretch for asking for the pic, it made me look closer at what was going on.
    Rj
  1. Use a wire feeder with my Power pro 164?
    By JCheney in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 10-13-2017, 03:41 PM
  2. iMIG 140e Wire Speed
    By Slartybartfa in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 01-16-2015, 01:58 AM
  3. Brainstorming the portable mig welding / suitcase wire feeder equipment
    By TheGary in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 12-08-2013, 04:45 PM
  4. Using your portable mig as a simple wire feeder w/gas powered welder - 100% dty cyl
    By sticks in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 11-04-2013, 01:11 PM
  5. Input power wire question 250EX
    By AWDnot2 in forum General Welder Questions
    Last Post: 11-29-2012, 07:43 PM
