Results 1 to 6 of 6
Thread: PP80S Duty Cycle
  1. Default PP80S Duty Cycle
    So I am confused what is the duty cycle on this unit. on page says 60% at 60amps and another say 100% at 63 amps. Which is correct?
    Also while i am at it. I am putting this on a plasma table replacing a ever-last unit that well =) shouldn't be used for cnc lol, and was looking at using using the pt-60 machine head rather then the pt-80. I don't plan on cutting over 1/4 or maybe 3/8 at most would the pt-60 torch be able to handle that? I do a lot more sign work where the lower amp/finer tips would be more beneficial, but still want to be able to cut 1/4. Would rather not have to run two heads or be switching heads.
    60% at 80 amps and 100% a 63 amps.
    The PT 80 torch has better consumable options.
    If you want the best options for thin kerf cutting, the S-45 machine torch would give you finer cuts. The ipt 80 torch would give you thicker capacity. Having two is ideal...the S-45 machine torch isn't that bad...but I wouldn't cut with it over 40 amps.
    Your unit also lists the specs onthe data plate.
    was thinking on getting this machine...was mostly gonna be cutting 1/8 5052 aluminum ...some are gonna be long cuts but must of them will be 6 to 8" holes...i know aluminum is a little harder to cut with plasma but does everyone think this unit will be good for this?
    250 ex
    205 mig
    milwaukee grinder
    140e mig
    The 60 or 80 will be fine for it.
  1. Duty cycle
    By joshuab in forum Stick Welding (SMAW)
    Last Post: 08-05-2013, 03:18 AM
  2. Power arc 160 STH duty cycle?
    Last Post: 06-15-2013, 02:45 PM
  3. 256 duty cycle
    By Blaze in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 08-27-2012, 06:14 AM
  4. PT185 duty cycle
    By K_phan in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-06-2011, 07:07 PM
  5. 100% Duty cycle
    By stick in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 03-09-2011, 02:07 PM
