Originally Posted by
azsprint6
Received an Everlast cooler yesterday and I searched for a thread I thought I saw about the Everlast torch water hose colors being backwards.
Didn't find the thread but to route them in the right direction doesn't that put the blue hose in the red connector and the red hose
in the blue?? Just checking, Thanks
Nope, the hose colors should be getting better but you need to check your actual torch to make sure. Quite a few people have hooked it up wrong because it is somewhat non intuitive if you are new to this. The best way to figure out the hoses is to blow in them one at a time. On one you will feel air coming out of the end of the torch (cup), that is your argon line. The hose coming out of the power plug is the water return line and goes in the red or IN port on your cooler. The last hose you have left is the water supply and that goes to the blue or OUT on the cooler. If the colors are right, that's great, but you never know. This way you will always get it right first time, and not get your argon hose all contaminated with coolant.
