Results 1 to 5 of 5
Thread: POWER I-MIG 200 Wire
    Default POWER I-MIG 200 Wire
    Looking at the specs on this machine - looks like .030 is the max wire size it will handle, or are there other rollers available for it?
    Everlast PowerTIG 200DV
    Cape Cod USA via Sydney Australia, via N.Z - yeah, I get around!
    My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
    Quote Originally Posted by ferntree View Post
    I believe you can use .030 and .035 with the included drive roll and a .035 contact tip. See pic> Click image for larger version.
ID:	13667 Other drive rollers are available through Everlast sales.
    This forum however can never be repaired to function correctly because Everlast has no interest in repairing it. "We're working on it" has been the standard reply for years with zero results.
    Yes, it can handle .035. Other rolls are available. Although you can get the .045" drive roll to fit, it doesn't mean its a good idea, or that the gun will support it.
    Thanks guys!
    If you keep it to .030 or .035 wire the sky is the limit with this machine, I run metal core threw mine.
  1. PowerUltra205 help needed. Won't power on, disconnected wire mystery location.
    By dsptech in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 11-18-2018, 04:47 PM
  2. Use a wire feeder with my Power pro 164?
    By JCheney in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 10-13-2017, 03:41 PM
  3. Power iMIG 275P Wire Feeder Alignment Question
    By Baronsbest in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 05-22-2016, 06:01 PM
  4. Input power wire question 250EX
    By AWDnot2 in forum General Welder Questions
    Last Post: 11-29-2012, 07:43 PM
  5. Replies: 26
