Results 1 to 5 of 5
Thread: Electrical Grounding Rod Driver Implement for a Pneumatic Chisel Gun
    Aug 2014
    Westerville, Ohio
    Default Electrical Grounding Rod Driver Implement for a Pneumatic Chisel Gun
    A good used SDS demolition hammer/drill on Craigslist still starts north of a C note. Let's see if $10.00 worth of Harbor Freight butchered and cobbled together originals can accomplish the ten foot electrical grounding rod driving chore?
    Buy pneumatic chisel set and half-inch drive 3/4" socket from Harbor Freight. Test fit socket/chisel combination on gun cutting to length. Hand lathe the chisel on the bench grinder to decrease the diameter of the cut end so it will fit in the through-hole of the socket. Weld the chisel/socket from both ends.
    Let us know how you make out with this setup.
    Mark
    Garage stuff
    Everlast 255 EXT
    Miller 251 mig
    30A spool gun
    Miller 211 mig
    Lincoln SP 250 mig
    Lincoln buzz box
    Thermal Dynamics
    Pakmaster 75XL plasma
    Aug 2014
    Westerville, Ohio
    A short test with rebar seemed to work well. The first attempt hit a baseball-sized rock three inches in the dirt. I was curious and dug it up off-camera.
    https://www.youtube.com/watch?v=Fi82oZG2uMk&t=15s
    Aug 2014
    Westerville, Ohio
    Sunk four 8' ground rods this past week as part of a grounding array. The pneumatic gun setup was perfect for starting the first three feet of the sink. Then, it was faster and easier to bang them in manually with a sledge.
    Still, I consider the effort a success due to the ease with which the first three feet started perfectly straight.
    Well it certainly sounds like you are a very grounded person. Sportsman Guide had some 5 ft. solid brass military surplus grounding rods I had some saved in my cart but I waited to long to purchase & they sold out.
    Mark
    Garage stuff
    Everlast 255 EXT
    Miller 251 mig
    30A spool gun
    Miller 211 mig
    Lincoln SP 250 mig
    Lincoln buzz box
    Thermal Dynamics
  1. Electrical info needed
    By Blaze in forum General Welder Questions
    Last Post: 03-23-2014, 07:25 PM
  2. Electrical Circuits
    By lucky13 in forum General Welder Questions
    Last Post: 05-08-2012, 11:51 AM
  3. powerarc 200 electrical hookup.
    By bobwills in forum Stick Welding (SMAW)
    Last Post: 12-27-2011, 07:46 PM
  4. HF grounding
    Last Post: 11-22-2011, 10:36 PM
  5. Powertig 250 EX on it's way.... Electrical question?
    By CGCINC in forum General Welder Questions
    Last Post: 10-22-2011, 10:38 PM
