Results 1 to 3 of 3
Thread: Texas.
  1. Default Texas.
    Apparently we are supposed to show where we are.
    So I have been welding for a few years off and on. I burned up a Crutchfield Hauser or some such cheap welder bought off of Craigslist. I'm not surprised. To get any kind of weld I had to put it on its highest setting (it had a symbol of a plug on it which I assume means whatever it could get from the 110v circuit). Funny thing was it quit while it was just sitting idle. Fan stopped, lights went out, dead.
    Sooo I have a new 200E. To say it's a step up is an understatement! I am in the process of mapping the dashes on the dials to real world measurements (FPM and voltage) and for that I do have a question. I am currently using a 110 circuit but will be upgrading to a 220 as soon as I figure out how to do it without electrocuting myself. I am wondering if the voltage readings I am getting now will change when I switch to the 220 circuit. Common sense says yes, but very little of the situations I have faced in welding follow common sense, at least to me.
    And here is the question for which I joined this forum and one I'm sure is answered somewhere already, but I can't find it.
    The 200E doesn't have a settings chart on the door for voltage and wire speed. But it occurs to me that these settings are not necessarily welder specific settings, but rather a function of the wire size and material size. So the setting for .035 on 1/4" material steel should more or less be the same across all welders (MIG, Fluxcore). Am I correct in this assumption? If so, then I would expect somewhere you can find a document that details these settings for a wide range of wires sizes, material types and sizes, no? If anyone can point me to such a document, I'd be appreciative.
    Other than that I've muddled my way through several projects from a trailer revitalization to a large Brick BBQ. Fun times! Seriously. Nothing better than creating useful stuff. Just need to avoid poisoning myself.
    Thanks for every pearl of wisdom that comes my way.
    BTW, I posted my two questions in the general welding forum. Probably best to answer then there if you were of a mind to.
    Welcome to the forum.
    Lincoln A/C 225
    Everlast P/A 200
  1. Another from Texas
    By Sherr20 in forum Introduce Yourself
    Last Post: 10-12-2018, 04:42 PM
  2. Hello from TEXAS
    By av8or1 in forum Introduce Yourself
    Last Post: 07-12-2018, 03:19 PM
  3. From Texas
    By Angus in forum Introduce Yourself
    Last Post: 04-09-2015, 11:53 PM
  4. texas tig
    By robt in forum Introduce Yourself
    Last Post: 02-25-2015, 04:05 AM
  5. Hi from Texas
    By dzljon in forum Introduce Yourself
    Last Post: 06-12-2014, 04:48 PM
Tags for this Thread
