Results 1 to 2 of 2
Thread: tig welding
    Default tig welding
    am accumulating wisdom in welding now. NEVER TIG WELD AT 2OO AMPS BARE-CHESTED. knew better, and did it anyway. won't do THAT anymore. peeling now.
  2. Default Re: tig welding
    Hammerbait,
    You are not the first I can assure you (I was in short and in a hurry one day, people thought I went to the beach TIG@180amps).
    Somtimes there will be an area you did not notice was not covered as well. TIG can really burn you. Watch the neck too and make sure you keep the shield down tight or collar closed up. Some older helmets had a guard on them.
    Hope the weld came out nice at least.
    http://www.everlastwelders.com
    http://www.everlastgenerators.com
  1. First Welding Project - You guessed it... a welding cart
