Results 1 to 2 of 2
Thread: high frequency ground question
    Default high frequency ground question
    So I'm anticipating the arrival of my pp256 here on thursday hopefully and trying to sort out the electrical stuff. This is a brand new shop but it seems no one had the foresight to run any 240 lines for future use. So it looks like I will be running my power supply right from the box that supplies one of the lifts. not a huge deal, and a lot easier than running it from the panel at the other side of the shop. one question. How critical is the hf ground? does it really need to be tied to a seperate grounding rod outside? My lifts are secured with 24 inch j bolts into the ground. Would it be sufficient to ground off to a lift ? My suspension tech has his alignment machine only maybe 15 feet away from where that power source would be. These target machines are state of the art and use IR pulses and reflectors t the wheels of the vehicle to take measurements. The flash of stick welding has never produced any problems for him but i dont know about hf interference. Any tips or experience?
    Brian
    Only ground it to a direct ground to earth. It is highly recommended to prevent interference and damage to surrounding electronic items, including to the machine itself.
  1. Pro 256 no HF (high frequency) start
    By jch13 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 07-01-2015, 11:24 PM
  2. 250ex high frequency staying on
    Last Post: 06-09-2014, 04:24 PM
  3. High Frequency Ground on back of 200DX
    By Shaggy in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-23-2014, 09:57 AM
  4. New PP256, high frequency start not working
    Last Post: 03-13-2013, 04:31 PM
  5. High-frequency ground and GFI breaker
    By MuttonHawg in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 02-06-2013, 03:24 PM
