Results 1 to 3 of 3
Thread: PowerPro 205 control voltage?
  1. Default PowerPro 205 control voltage?
    Thinking of adding a solenoid activated 3 way valve to control the selection of argon or compressed air for the appropriate process.
    What is the internal control voltage for the PowerPro 205 unit?
    Thanks!
    Probably the easiest way to do it would be use the TIG/CUT/MMA switch in the unit. Not sure what the voltage is, but you can take an volt meter and check it.
    If you are driving 2 solenoids you will need a little extra circuitry to toggle them, but nothing major.
    What is the voltage of the solenoids? Are you going to have your own power supply? Send over the voltage for the toggle if you need a hand.
    Thanks Mike...
    Simplest just to use a single solenoid valve. Commonly, 12 or 24 VAC/DC and occasionally 120 VAC coils are available.
    No problem to check, but thought you would know the unit's power supply outputs.
    Thanks again,
    Steve
  1. All NEW DUAL VOLTAGE Everlast PowerPro 164 AC/DC TIG / STICK / PLASMA CUTTER
    Last Post: 07-24-2013, 12:10 AM
  2. Help! Is my model I-Tig 200 dual voltage?
    By cornonda in forum General Welder Questions
    Last Post: 06-06-2013, 02:04 AM
  3. Max output voltage of a PP50?
    Last Post: 07-25-2012, 03:30 AM
  4. Dual Voltage PowerMTS?
    By posixPilot in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 03-31-2012, 02:56 PM
  5. Running iTIG 200 on 110 voltage
    By BradNes1 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-11-2011, 10:30 PM
