Whetn I start an arc I will get burn back of the wire to the tip or the wire will hit the workpiece two or three times with popping and you can see 1/2 inch long burnt wire along side the weld then the arc stabilizes and welds are as good as I can do. I had the arc force set half way and turned it down but have not noticed a difference, does that even matter in Mig? I am welding mild steel 1/4 inch Butt and lap steel is clean. settings are 21.4 voltage and 250 wire speed (300 inches min?)
I know I am missing something just cant put my finger on it yet
