Results 1 to 3 of 3
Thread: argon pressure
  1. Default argon pressure
    Hi,every tigger
    I am new 250ex owner.I have a question about regulator pressure.
    Is the pressure supposed to return to zero within around 10 seconds after I turn off the valve of the argon bottle?
    If it is abnormal to return to zero right away, does it mean that somewhere is leaking?
    No, the pressure should stay up for longer than that. Check your points where the hose clamps attach and retighten them.
    Jan 2010
    Chugiak , Alaska
    Use some soapy water and check for leaks around the regulator where the gauge screws in.
    ____
    Ray
    support@everlastalaska.com
    www.everlastalaska.com
    877-755-9353 X207
  1. Air Pressure
    By millermatic in forum Everlast Plasma Cutters (PAC)
    Last Post: 06-05-2013, 02:50 PM
  2. air pressure
    Last Post: 12-06-2012, 05:14 PM
  3. ARGON and ARGON/CO2 TANK SIZES
    Last Post: 10-13-2011, 05:19 AM
  4. U 205 second pressure regulator
    By docweathers in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-06-2011, 07:21 PM
