Results 1 to 3 of 3
Thread: Trouble shooting
  1. Default Trouble shooting
    Hello. I have a PowerPro 205. Had it in the shop for 5 months or so now. We ran a test when we first got it and it seemed to work then. I only made a few cuts in some 1/8 plate just to see that it was working.
    I went to use it the other day after it sat covered up for a few months and noting would happen after pulling the trigger. The machine turns on fine, but pulling the trigger does not start the air or create an arc. I double checked that the air was on, and it was. Is there something I can check, or some way to trouble shoot where the problem lies? I am really left scratching my head at this point.
    Thanks In advance
    Jan 2010
    Chugiak , Alaska
    Be sure the air pressure is between 60 – 75 psi on the regulator gauge. And that the consumables in the plasma torch are tight and in good shape.
    If that doesn’t do it give us a call.
    ____
    Ray
    support@everlastalaska.com
    www.everlastalaska.com
    877-755-9353 X207
    No air would typically be in your connections. Is the torch in the right hand side? Is the pilot arc and control wire hooked up?
    If so, you may have a loose trigger wire located in your torch. Remove the 4 screws and twist the black trim ring off the bottom, and gently remove the top half of the torch. Check to see if the wires are all in place.
  1. Trouble-shooting PP205 Plasma-
    By JBnID in forum Everlast Plasma Cutters (PAC)
    Last Post: 02-14-2013, 09:46 PM
  2. Replies: 20
    Last Post: 08-11-2011, 01:53 AM
  3. 256 a bit of trouble
    By ducksface in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 05-20-2011, 07:03 AM
  4. PM 256 2T/4T trouble
    By dwdw in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 04-03-2011, 05:14 PM
