Thread: Another aluminium welding cart
    Queensland, Australia
    Default Another aluminium welding cart
    Originally posted back in January but got lost in the forum software update…
    I see plenty of folks building welding carts here and especially like Dave’s diamond plate job.
    I was originally going to build one from steel but since receiving my PowerPro 205, I’ve gotten the aluminium welding bug. A good friend of mine constructed a TIG cart from square aluminium tubing a while back so I decided to go the same route and get in some welding practice.
    First job was to build the frame out of 25x25x3mm square tube. This used about 15m of tube. Bends were done on my mate’s home-made bender.
    Next came the sheet work. Shelves are cut out of 3mm sheet. I also added a piece of 6mm plate to mount the air regulator and another piece to secure the gas cylinder. The cable hangers are formed out of 12mm round bar.
    More to follow…
Name:	01 Frame1.jpg
ID:	739   Click image for larger version.
Name:	02 Frame2.jpg
ID:	740   Click image for larger version.
Name:	03 Tacking.jpg
ID:	738   Click image for larger version.
Name:	04 Sheeted1.jpg
ID:	741   Click image for larger version.
Name:	05 Sheeted2.jpg
    So here we have the finished cart. My new Everlast PP205 is angled back at 17° and my portable lightweight DC Tig/Stick welder sits on the flat shelf. I still have to add a bin to the bottom shelf to store my helmet, jacket, and gloves.
    Chris
    Brisbane Australia.
Name:	06 Finished1.jpg
ID:	743   Click image for larger version.
Name:	07 Finished2.jpg
ID:	744   Click image for larger version.
Name:	08 Finished3.jpg
ID:	745   Click image for larger version.
Name:	09 Finished4.jpg
ID:	746   Click image for larger version.
Name:	10 Plumbing.jpg
    This is my mate’s Tig cart that gave me the inspiration. His cart houses an EWM Triton 220 Tig along with a nice Thermal Dynamics Cutmaster 52 plasma.
    Hopefully our carts will give you some ideas.
    Chris.
ID:	748   Click image for larger version.
    Chris,
    Very nice cart, sure I probably mentioned that in the thread that was lost in our forum conversion. Thanks for re-posting. I'm sure all the members would want to see your work. I like the wheels all under the cart (on the new one) so not catch things and making it less wide. Guess with a bottle back there you need a little more wheel.
  1. bad contamination. cannot weld aluminium
    By js quebec in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-23-2017, 06:51 PM
  2. Smoother weld on AC aluminium with the torch positive, not negative.
    By PeterA in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 05-10-2017, 02:25 PM
  3. HF welding cart
    Last Post: 03-01-2013, 06:39 PM
  4. Welding Cart - Power Cart 250 - opinions?
  5. First Welding Project - You guessed it... a welding cart
