PowerPro 256D
  • Digital Microprocessor
  • Reliable IGBT Module Design
  • 9 function memory
  • Stick hot start
  • Stick arc force control
  • CC
$2,950.00You Save - $651.00
GTAW-P/SMAW/PAC
240V 1 Ph 50/60 Hz
PowerPro 164Si
  • Weld and cut in one package
  • 120V/240V Dual Voltage
  • Simple 1 Hz/ 25 Hz pulse
  • Cut up to 1/2"
  • CC
$1,425.00You Save - $226.00
$1,199.00 Buy Now
GTAW/SMAW/PAC
120/240V 1 Ph 50/60 Hz
20A TIG/Stick/Plasma
Price: $1,199.00
PowerPro 256Si
  • New! Digitally controlled IGBT inverter
  • Analog style controls for easy setup
  • Ideal for portable repair, shop, farm, HVAC and routine factory maintenance
  • 250A TIG/ 200A Stick/ 60A Plasma
  • New! 60% TIG Duty Cycle
  • Weld and cut in in one package
  • Fully adjustable pulse .5-500Hz
  • Cut up to 7/8"
  • CC
$1,925.00You Save - $126.00
GTAW/SMAW/PAC
240V 1Ph 50/60 Hz
5A DC TIG/Stick 20A AC TIG/Plasma
  • AC/DC Pulse TIG/ Stick/Plasma functions
  • Low air pressure cut-out to protect unit and plasma torch
SuperUltra 206Si
  • MOSFET design for Hobby use
  • CC
$759.00You Save - $210.00
$549.00 Buy Now
GTAW/SMAW/PAC
10A TIG/Stick/ 15A Plasma
35% at Max. Amps
Price: $549.00
  • Entry level MOSFET inverter
  • DC TIG, Stick, Plasma
  • Good for light hobby use
  • Dual Voltage
PowerUltra 206Pi
  • CC
$899.00You Save - $180.00
$719.00 Buy Now
GTAW-P/SMAW/PAC
  • 120/240V 1Ph 50/60Hz
10A TIG/Stick, 20 A Plasma
60% @ Max Amp Output
Price: $719.00
Ultra-Arc 205
  • Dual 120V/240V input
  • CC
$939.00You Save - $190.00
$749.00 Buy Now
GTAW-P/SMAW/PAC
120/240V 1 Phase 50/60Hz
5A TIG/Stick; 20A Plasma
Price: $749.00
  • Pulse TIG operation
  • Advanced Stick Features
