15 Series MIG Gun 5m 15 ft.
Everlast/Euro-Type Connector
$159.00
SKU# EV-MG15-5M
- Unit Weight: 5 lb
- Shipping Weight: 7 lb
The North 15 series MIG gun from Everlast interchanges with similar 15 series guns from other manufacturers Fits all Everlast MIG machines and any other brand with an Euro Style -Quick connect connector. Recommended up to 200A use. Blue .023"- .035" liner installed. Other liners available. For best operation, use a liner that is sized for the wire you are using. Blue .023-.035" liner is recommended for wire .035" and under. Don't forget the contact tips (see consumables) for the wire size you are using for best feeding.
| CO2 Amperage Rating | 180 Amps
| CO2 Duty Cycle @ Amperage Rating | 60%
| Ar/CO2 Amperage Rating | 150 Amps
| Ar/CO2 Duty Cycle @ Amperage Rating | 60%
| Gun Neck Type | Curved
| Gun Service Type | Standard Service
| Gun Handle Type | Ergonomic
| Stock Liner Wire Size | .023-.035”/.6-.9mm
| Liner Type | Steel
| Liner Color | Blue
| Cable Length | 15/3 Ft./Meters
| Cable Connector Type | Euro-Quick
| Water Connector Type | None, Air Cooled
| Protective Cable Cover Type | None
