500 A Bronze C-Clamp Work (Ground) Clamp with 10 Ft. Cable and DINSE 35 Connector
Work Clamps with Cables
$119.02
SKU# WC-500-C-10Ft.
- Unit Weight: 5 lb
- Shipping Weight: 5.98 lb
This 500A Bronze work clamp is a high amperage, C clamp style work clamp. This makes positive contact with the work to provide maximum arc stability. The replaceable cable lead is 10 Ft long and includes the DINSE 35 type connector (35/50 mm2). This DINSE 35 type connector (approximately 1/2" diameter plug pin) is typically used on larger Everlast units 200A and over. This clamp maximizes power flow and maximizes life span with the bronze construction. This clamp is best for high production welding, especially pulse MIG welding and sustained high Amp TIG welding on units such as the Typhoon 500.
