AW2000 Plasma Cutter Regulator for PowerPlasma  25i XTR, 52i, 62i,Hatchet, PowerPro 60, view 1
SKU# EV-AW2000-02-
Plasma Cutter Filters and Regulators
$48.99
SKU# EV-AW2000-02-
  • Unit Weight: 2 lb
  • Shipping Weight: 2.5 lb
This plasma cutter regulator is designed to regulate air pressure and flow before it enters the plasma cutter. It is designed to work with the PowerPlasma 52i and 100S/102i units. It also fits all Power Pro units. This unit has a separate hole for an optional external pressure gauge. If not used with a pressure gauge, a brass plug is required to fill the hole. (Pressure gauge and brass plug can be purchased separately under the parts category). The regulator also serves as a water trap to stop larger droplets of water from entering the plasma cutter's cutter air line that may result from the coupling/decoupling process of the quick connect air line fitting. The water trap is not meant to serve as a stand alone air dryer. A separate air dryer should be installed upstream of this unit. Mounting bracket not included.
