Cyclone 140E, view 1
Cyclone 140E, view 2
Cyclone 140E, view 3
Cyclone 140E, view 4
Cyclone 140E, view 5
Cyclone 140E, view 6
SKU# CLN-140E
MIG
$399.00
$379.00
Save - $20.00
MIG
SKU# CLN-140E
  • Unit Weight: 26 lb
  • Shipping Weight: 34.76 lb
  • Unit Dimensions: 8.5 in × 17.7 in × 12.5 in
The Cyclone 140E is an economy minded 120V welder that delivers serious MIG welding performance from a standard 120V power source. With a true 140A output and a 25% duty cycle at full power, this compact inverter welder offers a smooth, steady arc comparable to larger 240V machines—all at a price that keeps your budget in mind.
The Cyclone 140E makes setup easier with PowerSet mode, helping beginners select settings quickly while giving experienced welders a convenient starting point. The easy-to-read LCD screen clearly displays voltage and wire feed speed, allowing you to dial in precise settings and repeat them confidently.
A fresh design carries forward the Cyclone 140E’s emphasis on portability, making it easy to move between the garage, shop, and jobsite. Dedicated to MIG welding, it combines straightforward operation, strong output, and an impressive duty cycle in an affordable package built for practical, everyday use.
Key Features
  1. 120V operation for go-anywhere use.
  2. True 140A output at 25% duty cycle beats competitors
  3. Compact Inverter Design reduces size and weight
  4. Holds 8" (10-12 lb.) spools and 4" (2 lb) rolls of wire
  5. Basic powerset function simplifies setup
  6. Economical single board design makes it lighter and easier to repair
  2. 5000 Surge Watts
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 37 A
120V 1 Phase 50/60Hz: 19 A
3 inches
Type
Segmented LCD
Resolution
480
120V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 140A/21V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 90A/18.5V Rated Output
120V 1 Phase 50/60Hz MIG Amp DC Output Range: 25 to 140 Amps
120V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.3 to 140 Volts
68V
Fixed
Fixed
MIG Pulse
None
Spool Sizes
4”
8”
.023”
.030”
2
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
Wire Feed Speed
385 IPM
Torch/Gun
15 Series 10 Ft. (North)
24 gauge to 3/16"
22 gauge to 3/16"
1/8" (use .047" wire, with teflon liner in stock gun with U-groove drive rolls. Aluminum capability is limited. Spool gun is not recommended for best results.)
Downloads
