Cyclone 200ES, view 1
Cyclone 200ES, view 2
Cyclone 200ES, view 3
Cyclone 200ES, view 4
Cyclone 200ES, view 5
Cyclone 200ES, view 6
SKU# CLN-200ES
MIG
$639.00
$589.00
Save - $50.00
MIG
SKU# CLN-200ES
  • Unit Weight: 35 lb
  • Shipping Weight: 43 lb
  • Unit Dimensions: 9 in × 18 in × 13 in
The Everlast Cyclone 200ES is an economy minded dual-voltage MIG/Stick welder that combines strong performance, compact size, and straightforward controls, making it a practical choice for home garages, small shops, and portable repair work. Its simple layout keeps setup easy, while PowerSet helps beginners and experienced welders dial in their settings in seconds.
The reliable inverter design keeps the machine light enough to carry comfortably—even with an 8-inch, 12 lb. wire spool installed. Its modest power requirements also make it well suited for mobile repairs where generator capacity or available electrical power is limited.
  1. Dual 120/240V input for go anywhere performance
  2. Compact size and weight for maximum portability
  3. Additional basic Stick welding function for welding with iron powder and titania rods
  4. Basic version of the PowerSet function reduces setup complexity (PowerSet function not for use with Aluminum)
  5. 4" and 8" wire spool capacity
  2. 7500 Surge Watts
  1. This unit does allow use with a spool gun. However, due to lower wire speeds this unit has, the welding range for aluminum will be limited unless .047" wire is used. This unit performs best with a polymer liner in the Stock gun, using U-Groove drive rolls to feed from the main cabinet into the stock gun.
  2. This unit is not meant for Gas-Shielded Flux-Cored use. Do not use with this product.
  3. Do not use .023" and .030" wire with the optional 15 ft. MIG gun. Gun feeding issues will result.
  4. Do not use larger than .035" solid steel or stainless wire with this unit. With .035" or larger wire the machine may throttle back output to prevent damage to the machine as the wire feed speed selected may cause over Amperage. In this case, the welder may seem to sputter or feed irregularly.
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 30.2 A
240V 1 Phase 50/60Hz: 28.2 A
120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 15 A
4.3 inches
Type
Segmented LCD
Resolution
480
120V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 115A/19.75V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 75A/17.75V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 60A/17V Rated Output
240V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 180A/23V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 120A/20V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 90A/18.5V Rated Output
120V 1 Phase 50/60Hz MIG Amp AC Output Range: 30 to 200 Amps
120V 1 Phase 50/60Hz MIG Volt AC Output Range: 15.5 to 24 Volts
72V
Fixed
Fixed
MIG Pulse
None
Spool Sizes
4”
8”
.023”
.030”
2
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
Wire Feed Speed
120V: 360 240V: 480 IPM
Torch/Gun
15 Series 10 Ft. (North)
24 gauge to 1/4"
22 gauge to 1/4"
1/8" (use .047" wire, with teflon liner in stock gun with U-groove drive rolls. Aluminum capability is limited. Although the unit does support the use of a spool gun, the spool gun is not recommended for best results.)
Downloads
