SKU# CLN-212I
- Unit Weight: 59 lb
- Shipping Weight: 82 lb
- Unit Dimensions: 9 in × 18 in × 13 in
The Everlast Cyclone 212i is a professional dual-voltage MIG/Stick welder with basic DC Lift Arc TIG capability, built for commercial use. From shop fabrication to portable repairs, it delivers the reliability and stable arc performance professionals depend on. Adjustable welding controls let you tailor the arc to your preferences and the demands of each application.
The intuitive digital interface makes setup straightforward, with a dedicated, single-page screen for each welding process. All settings for the selected process—including advanced functions—are clearly displayed and easily accessible through simple navigation controls. With no hidden menus or pop-up pages to navigate, the Cyclone 212i helps you spend less time adjusting settings and more time welding.
- Dual 120/240V input for go anywhere performance
- 4.3" HD TFT screen
- Wire Jog for easier wire installation and changeover
- Basic DC Lift Start TIG function for use with optional gas valve TIG torch (TIG Rig)
- 4" and 8" wire spool capacity (2lbs. and 10-12lbs.)
- Can use spool gun or stock gun with polymer liner for Aluminum with U groove drive rolls.
- Additional polymer liner, U-groove drive roll and Spool Gun are optional
- 10,500 Surge Watts
- This welder performs best with .030" and .035" and solid wire sizes. .045/.047" sizes work best with aluminum and gasless flux-cored wires. With .023 and .030" diameter steel or stainless wires, do not use with guns longer than 10 Ft.
- This welder is not recommended for Gas-Shielded Flux-Cored operation. Choose a larger machine such as the Cyclone 262i for this type of operation.
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 33 A
240V 1 Phase 50/60Hz: 40 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 20 A
240V 1 Phase 50/60Hz: 20 A
| LCD Screen | 4.3 inches
| Type | TFT
| Resolution | HD 720
| Memory | 30 Programs
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 125A/20.3V Rated Output
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 15% Duty Cycle @ 40°C at 230A/25.5V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 125 Amps
| MIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 260 Amps
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 26.5 Volts
| Pre-Flow Time | 0-5 Seconds
| Post-Flow Time | 0-15 Seconds
| MIG Pulse | None
| Spool Sizes | 4”
8”
| Stock Drive Roll Wire Sizes Installed | .030”
.035”
| Number of Wire Drive Rolls (Top and Bottom) | 2
| Water Cooler Capable | No
| Spool Gun Capable | Yes
| Push Pull Gun Capable | No
| MIG Functions | Wire Jog
| Other MIG Functions | Spot
Stitch
| Wire Feed Speed | 120V: 400IPM 240V: 600IPM
| Torch/Gun | 24 Series 10 Ft. (North)
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 80A/23.2V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 175A/27V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 130A/25.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 100A/24V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 24 to 22.4 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 175 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 27 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 120A/15V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/14V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/13.2V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 230A/19.2V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 180A/17.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 140A/15.6V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 15 to 13.2 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 230 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 15 to 19.2 Volts
24 gauge to 5/16"
22 gauge to 5/16"
1/8-1/4"
1/16"- 5/32"
.015" to 1/4"
.015" to 1/4"
- 24 Series MIG Gun 3m 10 ft.
- 240V to 120V Pigtail adapter
