Cyclone 273DPi
SKU# CLN-273DPI
- Unit Weight: 70 lb
- Unit Dimensions: 11.25 in × 28 in × 18 in
The Everlast Cyclone 273DPi combines the precision of advanced Single and Double Pulse MIG technology with the speed and productivity of conventional MIG welding. Designed for professional fabrication, production, and repair, it delivers exceptional versatility across a wide range of material thicknesses, from thin sheet metal requiring precise heat control to heavier plate and structural applications demanding greater penetration.
The advanced Synergic Single and Double Pulse MIG system produces exceptionally smooth, clean welds with a uniform, bead appearance. Single pulse offers great control over heat and warping. When using Double Pulse, not only is there heat control, but in many applications, the finished weld is difficult to distinguish from TIG, making Double Pulse MIG a practical alternative when appearance, speed, and productivity matter. With significantly faster travel speeds than traditional TIG welding, the Cyclone 273DPi helps reduce production time without sacrificing weld quality.
Precise control over heat input and the weld puddle helps minimize distortion and burn-through on thinner materials while maintaining excellent performance on heavier sections. The pulse process also produces little to no spatter, virtually eliminating much of the grinding and post-weld cleanup associated with conventional MIG welding. The result is faster production, less finishing work, and greater overall efficiency.
When Double Pulse isn't needed, the Cyclone 273DPi offers Single Pulse MIG, conventional short-circuit, and spray arc MIG welding, allowing operators to match the process to the application. Whether welding steel, stainless steel, or aluminum, the intuitive synergic controls simplify setup and adjustment, making advanced pulse welding accessible without complicated programming.
From thin sheet metal to heavy fabrication, the Cyclone 273DPi delivers TIG-like weld appearance, professional-grade performance, and the production speed to improve your bottom line. With exceptional versatility, virtually spatter-free welding, and significantly reduced cleanup, it's a practical solution for shops looking to produce better-looking welds in less time.
- 240V 1 or 3 phase input
- 5.1" HD TFT screen
- Single and Double Pulse Synergic MIG with multiple wire/metal type selection for optimized performance
- Weld and Braze with MIG
- Can use spool gun or stock gun with polymer liner for Aluminum with U-groove drive rolls
- Includes 2 guns, liners, and drive rolls for steel and aluminum welding
- 13,500 Surge Watts recommended
- This welder ships with two 24 series MIG gun configured for a variety of welding needs. Heavy, sustained maximum amp welding may require a 36 series gun to be purchased. It comes with a red steel and a red polymer (for aluminum) liner for .040 and .045" wire installed. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A blue liner (.030–.035") is available for smaller wire. So, be sure to purchase additional liners to match the wire sizes you plan to use. In most cases .047" (aluminum) wire will be the best choice for all gauges of aluminum, thick or thin.
- Do not use .030" or smaller steel/stainless wire in a MIG gun longer than 12 feet. Do not feed aluminum wire smaller than .047"/ 3/64" / 1.2mm through standard gun. Always use polymer liner for feeding aluminum. This may require a liner change. 4043 may not feed well through main gun. Use 4943 instead. It is the preferred 40XX series for replacing 4043 wire.
240V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 53 A
240V 3 Phase 50/60Hz: 26 A
240V 3 Phase 50/60Hz: 21 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720 HD
| Memory | 30 Programs
| MIG Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 275A/27.8V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/24V Rated Output
| MIG Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz MIG Amp DC Output Range: 30 to 275 Amps
240V 3 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 27.8 Volts
| Open Circuit Voltage (OCV) | 75V
2T SP
4T SP
| MIG Pulse | Single and Double
| Spool Sizes | 8”
12”
| Wire Feeder Type | Internal/Self Contained Wire Feeder
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
| Wire Feed Speed | 600 IPM
| Torch/Gun | 24 Series 10 Ft. x 2
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/28V Rated Output
| Stick Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/28V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 160A/26.4V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 200 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 28 Volts
| Stick Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz Stick Amp DC Output Range: 10 to 200 Amps
240V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 28 Volts
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
24 gauge to 3/8"
22 gauge to 3/8"
.045-3/8"
1/16"- 3/16"
.020" to 3/8"
.020" to 3/8"
- Aerospace
- Contact Tip M6 Thread .035" and .045"
