Cyclone 313Pi
SKU# CLN-313PI-240
Built for the demands of professional fabrication and production environments, the Everlast Cyclone 313Pi combines advanced Synergic Single Pulse MIG technology, powerful Stick welding performance, and heavy-duty construction in one versatile welding system. Whether you're welding steel, stainless, or aluminum, handling production runs, or tackling heavy shop repairs, the Cyclone 313Pi delivers the power, precision, and flexibility to keep your operation moving.
The advanced Synergic Single Pulse MIG system produces exceptionally smooth, clean welds with virtually no spatter while helping reduce heat input and distortion. Pulse MIG also allows faster travel speeds compared to conventional short-circuit MIG, with improved puddle control for out-of-position welding. When the job calls for conventional MIG, the Cyclone 313Pi delivers equally impressive performance in both short-circuit and spray arc transfer modes, with up to 315A of MIG output.
But the Cyclone 313Pi is much more than a capable MIG welder. With up to 250A of DC Stick output, it delivers the kind of smooth, stable arc performance you'd expect from a dedicated Stick machine. Even demanding electrodes like E6010 are handled with confidence, making it easy to switch processes without sacrificing welding quality or productivity. From fabrication to repair and maintenance, the Cyclone 313Pi is ready for whatever the workday brings.
Designed for demanding shop environments, the Cyclone 313Pi features a heavy-duty wheeled undercarriage with an integrated protective roll cage that makes moving the machine around the shop easy while helping protect it from everyday bumps and impacts. The rear cylinder carrier accommodates gas cylinders up to 9 inches in diameter, while the full-size 12-inch spool capacity and heavy-duty four-roll wire drive system support wire spools weighing up to 44 lbs. Together, these features provide the durability and wire-feeding capacity needed for serious production work.
Advanced capability doesn't have to mean complicated operation. The Cyclone 313Pi features a large 5.1-inch HD TFT LCD display with a clean, intuitive single-screen interface. All major welding parameters are visible at a glance, eliminating the need to search through hidden menus or multiple screens just to make routine adjustments. Simple navigation keys and rotary controls put every essential setting within easy reach, allowing operators to spend less time programming and more time welding.
The Cyclone 313Pi brings together the performance of a professional Pulse MIG welder, the versatility of a powerful Stick machine, and the convenience of an easy-to-use digital interface—all in one shop-ready package.
- 240V input
- 5.1" HD TFT screen
- Single Pulse Synergic MIG with multiple wire/metal type selection for optimized performance
- Built in rolling chassis serves to protect welder and support the use of a gas cylinder (125 cu. ft or smaller recommended)
- Can use spool gun or stock gun with polymer liner for Aluminum with U groove drive rolls
- Additional polymer liner, U-Groove drive roll and Spool Gun are optional
- 16,500 Surge Watts
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 68 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 38 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720 HD
| Memory | 30 Programs
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 315A/29.8V Rated Output
| Open Circuit Voltage (OCV) | 84V
2T SP
4T SP
| MIG Pulse | Single
| MIG Pulse Pinch Effect | No
| Spool Sizes | 8”
12”
| Wire Feeder Type | Internal/Self Contained Wire Feeder
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
| Wire Feed Speed | 600 IPM
| Torch/Gun | 36 Series 15 Ft.
| Important MIG Specification Notes | This unit is Single Pulse only. It is not Double Pulse.
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 250A/30V Rated Output
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| Important TIG Specification Notes | This is basic DC Lift TIG. It does not support a foot pedal, or aluminum welding. Amp control is set only on the panel. A gas valve TIG torch such as a 17V should be used.
24 gauge to 1/2"
22 gauge to 1/2"
.045-7/16"
1/16"- 3/16"
.020" to 1/2"
.020" to 1/2"
- Aerospace
- 36 Series MIG Gun 3m 10 ft.
- Drive Roll Flux Core Double (Flux-Core Wire) – .045"-.062" (1.2-1.6mm)
- 6.5 Ft. Power Cord with NEMA 6-50 Plug
- Contact Tip M8 Thread
