Cyclone Wire Feeder FCS-203-AC For PowerMTS 400, view 1
Cyclone Wire Feeder FCS-203-AC For PowerMTS 400, view 2
SKU# EV-FCS-203-AC
Single Spool MIG Wire Feeders
$518.98
SKU# EV-FCS-203-AC
  • Unit Dimensions: 24 in × 10 in × 16 in
The FCS-203-AC wire feeder is designed to work with the PowerMTS 400 welder. The wire feeder has spool gun and push pull gun capability.
Maximum Wire Feed Speed
600 IPM
Amperage Rating
400 Amps
Maximum Spool Weight
44 lbs
Spool Diameter(s)
12"
Number of Spools
One
Display
No Display
Number of Drive Rolls
Four
Stock Feeder Drive Roll Sizes
.035"/.9mm
.040-/ 1.0mm.045 .045" (.047 or 3/64")/1.2mm
.062" (1/16") /1.6mm
Supports Gun Types
Spool Gun
Air-Cooled Push Pull-Gun
Maximum Recommended Operation Distance from Power Source
75 Ft./Meters
Compatible With
Everlast
Main Case Material Type
Steel
Type of Operation (s)
Manual
