Drive Roll Flux Core Double (Flux-Core Wire)
$40.00
SKU# EV-DR-FC-0608-2
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This 2 piece bottom-mounted X-groove Flux-Cored drive roller kit is serrated (hence the X shape) to grab and feed softer flux-cored wires (the drive roll is designated by either an X or K on the side following the size). In this configuration, the two lower "knurled" drive rollers grip and feed the wire, while the upper two rolls are typically a flat-surfaced idler that applies pressure to hold the wire in the lower roll’s groove. Only two grooved drive rolls are required. Select the appropriate drive roll for the type and diameter of wire you are using.
Keep in Mind:
- This is a two piece .023"-.030" drive X or K-groove drive roll kit which may have markings of 0.6-0.8mm equivalent groove sizes.
- It is an X or K-shaped Groove for Flux-Core wire feeding use. This grips the softer "cored" wires without slipping. It has two X shaped grooves with each groove being a different size.
- The wire size is stamped on the same side of the drive roll as the groove. The size is followed by the stamp of X or K. This arrangement is different from some companies, so pay attention during installation that the stamped size you desire to use is turned to the inside (subject to change, but take notice of which groove is larger or smaller).
