Drive Roll V-Groove Double (Steel/Stainless)
$40.00
SKU# EV-DR-VG-1216-2
This 2 piece bottom-mounted V-groove drive roll kit fits multiple Everlast MIG welders equipped with a four-roller wire feed system with a self-contained wire feeder (internal to unit). In this configuration, the lower drive rollers grip and feed the wire, while the upper two rolls are typically a flat-surfaced idler that applies pressure to hold the wire in the lower roll’s groove. Only two grooved drive rolls are required. Select the appropriate drive roll for the type and diameter of wire you are using.
Keep in Mind:
- This is a .045"-.062" drive roll which may have markings of 0.6mm-0.8mm equivalent groove sizes.
- It is V-Groove for Steel and Stainless solid wire feeding use. It has two grooves with a different size on each groove.
- .045" and .047" size wires use the same groove.
