Drive Roll V-Groove Single (Steel/Stainless)
$20.00
SKU# EV-DR-VG-0810
This bottom-mounted drive roll fits multiple Everlast MIG welders equipped with a two-roll wire feed system. In this configuration, the lower drive roll feeds the wire, while the upper roll is typically a flat-surfaced idler that applies pressure to hold the wire in the lower roll’s groove. Only one grooved drive roll is required. Select the appropriate drive roll for the type and diameter of wire you are using.
Keep in Mind:
- This is a .030"-.040" drive roll which may have markings of 0.8mm-1.0mm equivalent groove sizes.
- It is V-Groove for Steel and Stainless solid wire feeding use.
