Electra-Force 500d   Dual Station, view 1
SKU# EF-500D-DS
Engine Drive
$28,999.00
$25,999.00
Save - $3,000.00
Engine Drive
SKU# EF-500D-DS
  • Unit Weight: 1700 lb
  • Shipping Weight: 1900 lb
  • Unit Dimensions: 37.2 in × 71.5 in × 42 in
The Electra-Force 500D Dual Station is a multiprocess diesel engine driven welder built for field work. Powered by a 3.3 L Yanmar engine, it delivers up to 500 A in single station mode or 300 A at each station in dual station mode. It supports downhill welding with E6010 electrodes and a wide range of other welding rods. With optional accessories, it also supports DC TIG, MIG, and flux core welding. Gouging capability adds versatility on the jobsite, while remote start and foot pedal support give operators more control.
The 1,800 RPM Yanmar® 4TNV98C-GGE Tier 4 Final engine also powers the unit’s 480 V three phase generator output, rated at 25,000 W continuous and 27,000 W surge. Its emissions system uses a diesel particulate filter without requiring DEF. The filter has a stated 6,000 hour service life, and regeneration does not require an increase in engine speed.
For demanding environments, the industrial inverter design uses potted circuit boards and sealed components. A 20 gallon fuel tank provides the capacity to work through a full shift.
  1. Yanmar® 3.3L diesel Power with 55.7Hp @ 1800 r.p.m
  2. 27,000W 480V 3 phase
  3. 19,000W 240V 1 phase
  4. 7,500W 120V 1 phase
  5. NEMA 14-50 and 6-50 240V outlets standard
  6. Two 120V 20A 5-20 GCFI outlets
  7. One 480V outlet
  8. E6010 capable
  9. MIG, TIG, Stick output
  10. Gouge function
  11. Adjustable engine idle down timer
  12. Digital operator panel
Use only Ultra low sulfur off-road diesel in this unit.
Engine is serviced separately by Yanmar®
120V 1 Phase 50/60Hz
480V 3 Phase 50/60Hz
Fuel Type
Diesel
Engine Maker
Yanmar®
Engine Model
4TNV98C-GGE
Engine Horsepower
55. HP
Fuel Capacity
20
Rated Engine R.P.M.
1800 RPM
Cylinders
4
Cooling Method
Water
Oil Capacity
10.5L
Auto Shut-Down
Tier Rating (Emissions)
T4F
Welder Type
Inverter
Number of Operator Stations
Two
Welding Processes
DC Stick, MIG/Flux-Cored, TIG, Gouge
Amp Output Range
30-500A
Dual User Amp Output Range
30-300A
Duty Cycle
Dual User Duty Cycle
Power Connector Types
Stud
Arc Force
Rated Carbon Arc
Peak Generator Output
27,000W
Continuous Generator Output
25,000W
  • Rail Car Industry
  • Pipe and Structural
2 Year Warranty
