Everlast 18 Series Water-Cooled Amp Control TIG Torch 25 Ft. 35 DINSE-Type Connector (No Gas Thru), view 1
SKU# EV-18-AMP-CNTRL-25
18 Series
$309.00
18 Series
The Water-Cooled Everlast 18 Series Amp Control torch allows amp control in combination with the 2T/4T controls on the welder. Recommended for Typhoon welders. Other units the torch may only work in 4T mode. It is designed to signal the upslope and downslope cycles, as well as the arc start and termination separately from the Amp adjustment. The torch has a rigid (fixed, non flex) neck design. The torch features separate on/off button along with a rotating North/South Amp control wheel built into the torch body. The Euro torch handle allows a comfortable grip. This torch is only designed for slight modification to Amperage while welding. It is not meant as a substitute for a foot pedal, since it has a separate torch switch that must activate and terminate the arc. This type of separate torch switch arrangement means that the adjustment of the amperage should be done before starting the weld rather during welding. It is not meant to roll-on and roll-off the Amperage while welding.
250 Amps
100%
350 Amps
Torch Neck Type
Straight/Rigid
Torch Service Type
Torch Handle Type
Euro
Torch Remote Switch Included
Torch Cable Type
Standard (Rubber)
Number of Main Cables
Three Line Water Cooled
Cable Length
25 Ft.
Cable Power Adapter Size/Type
DINSE 35 Type (Solid)
Gas Connector Type
Water Connector Type
