Everlast 9 Series Air-Cooled Amp Control TIG Torch 12.5 Ft. 35 DINSE-Type Connector (No Gas Thru), view 1
SKU# EV-9-AMP-CNTRL-125
9 Series (125A Max)
$209.00
9 Series (125A Max)
  • Unit Weight: 5 lb
  • Shipping Weight: 7 lb
The Everlast 9 Series Amp Control allows amp control in combination with the 2T/4T controls on the welder. Recommended for Typhoon welders. Other units the torch may only work in 4T mode. It is designed to signal the upslope and downslope cycles, as well as the arc start and termination separately from the Amp adjustment. The torch has a rigid (fixed, non flex) neck design. The torch features separate on/off button along with a rotating North/South Amp control wheel built into the torch body. The Euro torch handle allows a comfortable grip. This torch is only designed for slight modification to Amperage while welding. It is not meant as a substitute for a foot pedal, since it has a separate torch switch that must activate and terminate the arc. This type of separate torch switch arrangement means that the adjustment of the amperage should be done before starting the weld rather during welding. It is not meant to roll-on and roll-off the Amperage while welding due to the separate switch configuration. Amperage can be adjusted while welding but, a full ramp up and down works against the programmingdue to the separate switch configuration. Amperage can be adjusted while welding but, a full ramp up and down works against the programming due to the separate switch configuration. Amperage can be adjusted while welding but, a full ramp up and down works against the programming.
80 Amps
125 Amps
Torch Neck Type
Straight/Rigid
Torch Service Type
Torch Handle Type
Euro
Torch Remote Switch Included
Torch Cable Type
Standard (Rubber)
Number of Main Cables
Single Line Air-Cooled
Cable Length
12.5 Ft.
Cable Power Adapter Size/Type
DINSE 35 Type (Solid)
Gas Connector Type
