IPT-100 Hand Plasma Torch Blow Back Start 24 Ft. Central Connector
Blow-Back/Non HF
$569.00
Blow-Back/Non HF
SKU# EV-IPT100-24C
- Unit Weight: 8 lb
- Shipping Weight: 12 lb
- Unit Dimensions: 20 in × 20 in × 3 in
The iPT 100 is a non-contact, blow back start style 100A rated torch with pilot arc designed for hand cutting. Natively fits PowerPlasma 102i plasma cutters. It also fits older model Powerplasma 100S models. Consumables should be changed to fit the Amperage. Can be fitted with cutting consumables ranging from 40-100A in capacity (1.0-1.5mm orifice). This type of torch uses the consumable shoulder to initiate the arc by "blowing back" the spring loaded consumable with air pressure during start to strike an arc. (This is the standard type start for most modern plasma cuttings systems under 150A.)
| Torch Amperage Rating | 100 Amps
| Torch Connector Type | Euro-Central Connector
| Cooling Type | Air-Cooled
| Cable Length | 24 Ft.
