IPT-60 Hand Plasma Torch Blow Back Start 14 Ft. Threaded Connector
SKU# EV-IPT60-14T
- Unit Weight: 6 lb
- Shipping Weight: 9 lb
- Unit Dimensions: 20 in × 20 in × 3 in
The iPT 60 is a non-contact, blow back start style 60A rated torch with pilot arc designed for hand cutting. Natively fits new PowerPro D and Si models with Dinse Connector. Also fits older PowerPro S models and UltraArc with DINSE connector. DINSE connector/adapter NOT included. The threaded connection screws onto the DINSE connector supplied with the welder. If the DINSE connector is lost or broken, please see our parts section for replacements to fit this torch. This torch has a separate pilot arc wire and a separate control wire for the torch switch. Consumables should be changed to fit the Amperage. Can be fitted with consumables ranging from 20-60A in capacity (.6-1.1mm orifice). This type of torch uses the consumable shoulder to initiate the arc by "blowing back" the spring loaded consumable with air pressure during start to strike an arc. (This is the standard type start for most modern plasma cuttings systems under 150A.)
| Torch Amperage Rating | 60 Amps
| Cooling Type | Air-Cooled
| Cable Length | 14 Ft.
