iPT-60 Hand Plasma Torch Blow Back Start 24 Ft. Central Connector, view 1
iPT-60 Hand Plasma Torch Blow Back Start 24 Ft. Central Connector, view 2
SKU# EV-IPT60-24C
Blow-Back/Non HF
$399.00
Blow-Back/Non HF
SKU# EV-IPT60-24C
  • Unit Weight: 6 lb
  • Shipping Weight: 10 lb
The iPT 60 is a non-contact, blow back start style 60A rated torch with pilot arc designed for hand cutting. Fits all Everlast plasma cutters with a Euro Central Connector. Natively fits PowerPlasma 50S, 52i, 60S, 62i, and Hatchet 60 plasma cutters. It can be used on other units, but the maximum power is not to exceed 60 Amps. Consumables should be changed to fit the Amperage. Can be fitted with consumables ranging from 20-60A in capacity (.6-1.1mm orifice). This type of torch uses the consumable shoulder to initiate the arc by "blowing back" the spring loaded consumable with air pressure during start to strike an arc. (This is the standard type start for most modern plasma cuttings systems under 150A.
Torch Amperage Rating
60 Amps
Torch Connector Type
Euro-Central Connector
Cooling Type
Air-Cooled
Cable Length
24 Ft.
