Large Drive Roll V-Groove Double (Steel/Stainless) for External Feeders
SKU# EV-LG-VG-0608-2
  • Unit Weight: 1 lb
  • Shipping Weight: 2 lb
This large 2 piece bottom-mounted V-groove drive roll kit fits most Everlast external wire feeders equipped with a four-roller wire feed system. In this configuration, the lower drive rollers grip and feed the wire, while the upper two rolls are typically a flat-surfaced idler that applies pressure to hold the wire in the lower roll’s groove. Only two grooved drive rolls are required. Select the appropriate drive roll for the type and diameter of wire you are using. Be sure to match up the drive roll appearance with the drive roll you are ordering. Does not fit the Cyclone 513DPi external wire feeder. Confirm match before ordering. If in doubt confirm with Everlast parts department at 877-755-9353 ext 206.
Keep in Mind:
  1. This is a .023"-.030" drive roll which may have markings of 0.6-0.8mm equivalent groove sizes.
  2. It is V-Groove for Steel and Stainless solid wire feeding use. It has two grooves with a different size on each groove.
