Lightning 275 MTS & W401 Cooler & Cart 301 & Nova Kit (Bundle)
SKU# LMTS-275-240-301-W401
- Unit Weight: 95 lb
- Unit Dimensions: 11.5 in × 26 in × 25 in
This bundle package has been created with the professional in mind. It offers the Lightning 275, the PowerCool 401 and the heavy duty PowerCart 301 as part of the bundle package. This package includes pretty much everything you might need to weld pretty much anything in the shop. It includes all the standard accessories included with the Lightning MTS 275 120/240V model.
Includes:
- Lightning 275 MTS (Dual Voltage 120/240V model)
- Lightning 275 MTS accessory package
- PowerCool 401 Water Cooler
- PowerCart 301 Single Cylinder Welding Cart
- Surge Watts 13,500
- This welder ships with a water-cooled 18 Series TIG Torch. If you want to use without a water cooler, you will need to purchase a 26 series air-cooled TIG torch.
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 43 A
240V 1 Phase 50/60Hz: 53 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 34 A
240V 1 Phase 50/60Hz: 41 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720
| Memory | 30 Programs
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 150A/21.5V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 120A/20V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 150 Amps
| Up-Slope Time | 0-1 Seconds
| MIG Pulse | None
| Spool Sizes | 8”
12”
V-Groove
V-Groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
Spot
Stitch
| Wire Feed Speed | 120V: 425IPM 240V: 600 IPM
| Torch/Gun | North 36 Series 10 Ft.
| Important MIG Specification Notes | his unit is equipped with a heavy duty 36 series MIG gun designed for Spray arc welding and using larger .045" and .062" wires. If welding below 230A, purchase a 24 Series gun. If using .035" or smaller wire, also purchase a blue .023"-.035" liner for the 24 series or 36 series gun.
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 150A/16V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 275A/21V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 15 to 150 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.6 to 16 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 150 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 16 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 15 to 275 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.6 to 21 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 225 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 19 Volts
Live Lift Start
| Start Amp Range AC | 15-(150)275A
| Start Amp Range DC | 10-(150)275A
| End Amp Range AC | 15-(150)275A
| End Amp Range DC | 10-(125)275A
| Pre-Flow Time | 0-5 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Soft Square
Triangular
| Pulse Amperage | 3-95% of Welding Amperage
| AC Frequency | 20-250 Hz
| AC Wave Forms | Square
Soft Square
Triangular
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 120A/24.8V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 90A/23.6V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 220A/28.8V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 120 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24.8 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 220 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 28.8 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 7/16""
.015" to 5/16"
.015" to 5/16"
.025"- 5/16"
1/16"- 7/32"
- Rail Car Industry
- Pipe and Structural
- 36 Series MIG Gun 3m 10 ft.
- 240V to 120V Pigtail Adapter
- Starter Consumable TIG Kit
- 6.5 Ft Power Cable with NEMA 6-50 Power Plug
