Lightning MTS 275-P, view 1
Lightning MTS 275-P, view 2
Lightning MTS 275-P, view 3
Lightning MTS 275-P, view 4
SKU# LMTS-275-PULSE
Lightning MTS 275-P
Pulse MIG
$2,600.00
$2,499.00
Save - $101.00
Lightning MTS 275-P
Pulse MIG
SKU# LMTS-275-PULSE
  • Unit Weight: 97 lb
  • Unit Dimensions: 11.5 in × 26 in × 25 in
Lightning MTS 275-P
The Lightning 275P MTS is a professional multi-process welder built to tackle the variety of work that comes through a busy shop. Combining 275A MIG, 275A AC/DC Pulse TIG and 220A DC Stick capability, it brings serious power and versatility to fabrication, repair and production work. New Synergic Single Pulse MIG helps control heat on sensitive materials, reduce spatter and increase travel speed—giving you another way to handle demanding jobs with confidence.
From short-circuit MIG to spray arc and pulsed spray, the Lightning 275P MTS covers a wide range of applications. Dedicated aluminum, stainless steel, gas-shielded and gasless flux-cored settings simplify setup, while push-pull gun capability expands its aluminum welding versatility. AC/DC Pulse TIG adds precise control, with an updated HV start system for more efficient arc starts. Stick mode handles a broad range of electrodes, including E6010.
PowerSET gets you welding faster by suggesting starting settings from basic information entered in MIG, TIG or Stick mode. Each process displays all settings on one clear page, with no hidden menus or popups. You can also name, save and lock up to 30 custom programs for repeat jobs.
Built to keep working, the unit delivers 60% duty cycle at maximum rated output in each process, plus 100% duty cycle at 200A in MIG and TIG or 175A in Stick. Dual-voltage operation lets you take it to jobsites with 120V power when needed, with reduced output. Whether you’re welding thin material or tackling heavier fabrication, the Lightning 275P MTS puts the tools for the job in one machine.
  1. Fully Synergic Pulse MIG
  2. AC and DC Pulse TIG
  3. PowerSET mode for easy setup of parameters.
  4. Dual Voltage Operation allows maximum go-anywhere performance
  5. MIG, AC/DC Pulse TIG and Stick operation handles almost any common welding chore
  6. Cart and cooler for TIG available as an option and works with rear outlet
  7. Spool gun and push-pull gun capable (Guns are optional)
  8. Run-in features improves arc starting in MIG mode
  9. 5.1" LCD HD 720 Screen for easy view of parameters
  10. 4 Roller drive system for smooth feeding of wire on longer guns and push-pull guns
  11. 12" or 8" roll capacity (10-12 lb. or 30-44lb.) provide economical choices of wire selection.
  12. Save up to 30 programs
  2. Surge Watts 13,500
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 43 A
240V 1 Phase 50/60Hz: 53 A
120V 1 Phase 50/60Hz: 34 A
240V 1 Phase 50/60Hz: 41 A
5.1 inches
Type
TFT
Resolution
720
30 Programs
Cooler Control
Runs Continuously
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 150A/21.5V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 120A/20V Rated Output
120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 150 Amps
80V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
MIG Hot Start
Adjustable
MIG Hot Start Duration
Adjustable
MIG Crater Fill (End Fill)
Adjustable
Adjustable
0-10 Seconds
0-30 Seconds
0-1 Seconds
0-1 Seconds
2T SP
4T SP
MIG Pulse
Single
MIG Pulse Pinch Effect
MIG Pulse Operation
Synergic
Spool Sizes
8”
12”
.035”
V-Groove
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Arc Trim (Pulse)
Run-In
Spot
Stitch
Wire Feed Speed
120V: 425 IPM 240V: 600 IPM
Torch/Gun
North 36 Series 10 Ft.
This unit is equipped with a heavy duty 36 series MIG gun designed for Spray arc welding and using larger .045" and .062" wires. If welding below 230A, purchase a 24 Series gun. If using .035" or smaller wire, also purchase a blue .023"-.035" liner for the 24 series gun or the 36 series gun
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 7/16""
.015" to 5/16"
.015" to 5/16"
.025"- 5/16"
Downloads
