LTM-151 CNC/Machine Torch Blow Back Start 25 Ft. Threaded Connector
High Frequency
$699.00
High Frequency
SKU# EV-LTM151-25t
- Unit Weight: 7 lb
- Shipping Weight: 11 lb
- Unit Dimensions: 24 in × 24 in × 3 in
The LTM-151 is a HIgh Frequency 1510A rated machine torch with pilot arc designed for CNC and Automated cutting. Natively fits the industrial PowerPlasma 151H. Consumables should be changed to fit the Amperage. Can be fitted with consumables ranging from 50-150A in capacity (1.1-1.8 mm orifice). This type of torch uses HF for starting the arc. (This is the standard type start for most industrial plasma systems over 150A.) Due to the industrial intent of this torch, and the start style used the torch and plasma cutter should only be used on fully shielded CNC/Automated cut systems that are designed to operate with the interference caused by HF start.
| Torch Amperage Rating | 150 Amps
| Torch Connector Type | Threaded Connector
| Cooling Type | Air-Cooled
| Cable Length | 25 Ft.
