North MPG 300A Air-Cooled Push-Pull Gun Fits Everlast 25 Ft. Euro Quick Connect, view 1
North MPG 300A Air-Cooled Push-Pull Gun Fits Everlast 25 Ft. Euro Quick Connect, view 2
North MPG 300A Air-Cooled Push-Pull Gun Fits Everlast 25 Ft. Euro Quick Connect, view 3
North MPG 300A Air-Cooled Push-Pull Gun Fits Everlast 25 Ft. Euro Quick Connect, view 4
SKU# EV-MPG300A-25
Inline, Conventional Type
$2,099.00
SKU# EV-MPG300A-25
  • Unit Weight: 14 lb
  • Shipping Weight: 16 lb
  • Unit Dimensions: 25 in × 24 in × 3 in
The North 300A air-cooled push-pull gun is an inline style that fits more like a traditional MIG gun in the hand with only a slightly wider body. It natively fits new Cyclone 262i, 312i, 263Pi, 313Pi, 253DPi and 353DPI. It also fits new-style Lightning 275/ 275P models as well as Thunder215 and 255 models that are push-pull capable. It comes fitted with a .045" drive roll for feeding Aluminum. Additional Drive rolls available as an option It can also be retrofitted to work with older Power i-MIG models that feature push-pull capability such as the Power i-MIG 253DPi and Power i-MIG 353DPi, This cannot be used on older Lightning or PowerMTS models. ThisPistol Grip gun comes the larger 7 pin connector and will require a 2 pin adapter to work with older Power i-MIG models mentioned above. This design allows Wire Feed/Amp control at the gun on all new models. Wire feed speed control on the gun is only supported on newer models. The speed control on older models will not work and wire speed control must be controlled on the panel.
CO2 Amperage Rating
290 Amps
CO2 Duty Cycle @ Amperage Rating
Ar/CO2 Amperage Rating
260 Amps
Ar/CO2 Duty Cycle @ Amperage Rating
Gun Neck Type
Curved
Stock Drive Roll Size(s)
.045/.047"(3/64")/1.2mm
Amp Control Type
Amp/Wire Feed Control on Gun
Cable Length
25/8 Ft./Meters
Cable Connector Type
Euro-Quick
