North MPW 400A Water-Cooled Push-Pull Gun Fits Everlast 25 Ft. Euro Quick Connect
SKU# EV-MPW400A-25
- Unit Weight: 13 lb
- Shipping Weight: 16 lb
- Unit Dimensions: 24 in × 24 in × 3 in
The North 400A water-cooled push-pull gun is an inline style that fits more like a traditional MIG gun in the hand with only a slightly wider body. It natively fits and is recommended for the new Cyclone 312, 313Pi, 353DPI and 503DPi. It can also fit other units but is only recommended for the larger units over 300A with a built in water cooler plug. It comes fitted with a .045" drive roll for feeding Aluminum. Additional Drive rolls available as an option It can also be retrofitted to work with older Power i-MIG models that feature push-pull capability such as the Power i-MIG 253DPi and Power i-MIG 353DPi, This cannot be used on older Lightning or PowerMTS models. ThisPistol Grip gun comes the larger 7 pin connector and will require a 2 pin adapter to work with older Power i-MIG models mentioned above. This design allows Wire Feed/Amp control at the gun on all new models. Wire feed speed control on the gun is only supported on newer models. The speed control on older models will not work and wire speed control must be controlled on the panel.
| CO2 Amperage Rating | 450 Amps
| CO2 Duty Cycle @ Amperage Rating | 100%
| Ar/CO2 Amperage Rating | 400 Amps
| Ar/CO2 Duty Cycle @ Amperage Rating | 100%
| Gun Neck Type | Curved
| Stock Drive Roll Size(s) | .045/.047"(3/64")/1.2mm
| Amp Control Type | Amp/Wire Feed Control on Gun
| Cable Length | 25/8 Ft./Meters
| Cable Connector Type | Euro-Quick
