North SM200N Spool Gun 20 Ft. Euro Quick Connector
Pistol Grip
$399.00
Pistol Grip
SKU# EV-SM200N
- Unit Weight: 6 lb
- Shipping Weight: 9 lb
- Unit Dimensions: 24 in × 24 in
The 200A North SM200N spool gun fits older model Power i-MIG units 200A and under no longer in production. Not recommended for use with any current units. This gun features the larger 7 pin connector. This design does not allow Wire Feed/Amp control at the gun. Wire Feed Speed is controlled on the panel only with this gun. It comes fitted with a .030-.035" drive roll for feeding Aluminum. For best results use .035" or order an .045" drive roll for Aluminum. The lower wire speeds produced by older/smaller units do not produce high enough wire feed speeds to support .030" Aluminum wire.
| CO2 Amperage Rating | 200 Amps
| CO2 Duty Cycle @ Amperage Rating | 60%
| Ar/CO2 Amperage Rating | 160 Amps
| Ar/CO2 Duty Cycle @ Amperage Rating | 60%
| Gun Neck Type | Straight
| Stock Drive Roll Size(s) | .030"/.8mm
.035"/.9mm
| Amp Control Type | No Gun Amp/Wire Feed Control/Panel Control Only
| Cable Length | 20/6Ft./Meters
| Cable Connector Type | Euro-Quick
| Protective Cable Cover Type | Denim
