NOVA 20 Series Water-Cooled Rigid-Neck TIG Torch 12.5 Ft. 35 DINSE-Type Connector (No Gas Thru), view 1
NOVA 20 Series Water-Cooled Rigid-Neck TIG Torch 12.5 Ft. 35 DINSE-Type Connector (No Gas Thru), view 2
SKU# NVA-20R-125-UF-35QD
20 Series
$149.00
20 Series
  • Unit Weight: 5 lb
  • Shipping Weight: 6 lb
The NOVA 20 Series Air-Cooled TIG torch (3.0 Version) features a non-adjustable neck design with improved durability and flexibility of the Ultra-Flex torch cables over previous Nova 1.0 and 2.0 versions. The torch design is of a universal WP- type TIG torch design which means compatible consumables are available at almost any local welding supply store that sells TIG accessories. The sturdy fixed neck design is meant for rugged use and resists torch breakage. It is rated for 250A DC and 175Amps AC use at 100% duty cycle. The 3 line ultra-flex cable design maximizes portability and reduces total weight thanks to the food-grade silicone based torch cables. While the torch can be used at higher that the rated 100% duty cycle Amperages, the user should be conscious of the limits of the torch and be aware that duty cycle begins to fall as the rated amperage is surpassed. The 35 DINSE-Type power connector measures approximately 1/2" in diameter at the connector pin and fits Everlast all Everlast PowerTIG, PowerPro, and Typhoon, Lightning and Thunder units that are rated for 200A or more with automatic gas control. It also fits later model PowerTIG 185 units, PowerPro 164Si and others. NOTE: Measure inside female diameter of the machine-side power connector to confirm fit. DINSE 25 connectors are smaller and measure approximately 3/8" inside the female connector. This is not a gas-valve torch.
A 2T/4T remote torch switch included. (The switch is meant to control the remote program settings preset on the panel and does not directly control Amperage on the torch).
