NOVA 26 Series Air-Cooled Rigid Neck TIG Torch 12.5 Ft. 35 DINSE-Type Connector (No Gas Thru)
SKU# NVA-26R-125-35QD
- Unit Weight: 4 lb
- Shipping Weight: 6 lb
- Unit Dimensions: 16 in × 16 in × 24 in
The NOVA 26 Rigid Series Air-Cooled TIG torch (3.0 Version) features a non-adjustable neck design with improved durability and flexibility of the Ultra-Flex torch cables over previous Nova 1.0 and 2.0 versions. The torch design is of a universal WP- type TIG torch design which means compatible consumables are available at almost any local welding supply store that sells TIG accessories. The new 3.0 versions feature food grade silicone ultraflex lines and larger ports in the head for better gas flow and cooling. The sturdy fixed neck design is meant for rugged use and resists torch breakage. It is rated for 150A DC and 120Amps AC use at 60% duty cycle. The traditional single line cable-in-gas-line design maximizes portability and reduces total weight thanks to the silicone based torch cables. The torch is compact as the 9 series from the neck to the handle, but uses the larger 26 and 18 series consumables. For maximum performance in close quarters or for reduced profile, consider the Stubby adapter kit to adapt 9 series consumables to the torch. While the torch can be used at higher Amperages, the user should be conscious of the limits of the torch. The 35 DINSE-Type power connector measures approximately 1/2" in diameter at the connector pin and fits Everlast all Everlast PowerTIG, PowerPro, and Typhoon, Lightning and Thunder units that are rated for 200A or more with automatic gas control. It also fits later model PowerTIG 185 units, PowerPro 164Si and others. NOTE: Measure inside female diameter of the machine-side power connector to confirm fit. DINSE 25 connectors are smaller and measure approximately 3/8" inside the female connector. This is not a gas-valve torch.
| Cable Length | 12.5 Ft.
